why does the soliworks enter to a 3d sketch when i make a drilling?
simple drilling
you need to select the surface where you would like to place the drilling before selecting the hole command, otherwise it has no idea where to even start to place the hole. This should correct the issue you are having.
you mean creating a sketch on this selected surface!!!!
