Why is osnap offset on latest AutoCAD?
i just downloaded fresh autocad and for some reason theres osnap offset about 0.0006 or so. This is just circles, on straight lines it takes correctly.
Check you setting in AutoCAD- Options-Display-Display Resolution - Arc and Circle Smoothness. I had an early version AutoCAD that showed radii as being offset unless this value was set to 10000 or more, some sort of video driver issue, but htis was the work around.
didnt work :( i puted smoothness up to 20000 put still it was offset
i just noticed that offset isnt always same its different with other circles
