why pockets are not shown in catia
when i cut pocket in catia then it doesnt show in my model
what is the problem plzz tell me
there are many reason for becoming it .generally pocket is similar to pad but it negative process. during making part in part design if you are given pad its shown similarly if you are given pocket its shown..
Pocket is negative operation, it removes material stock if created in the same BODY, other wise act as PAD, in a new BODY. use Boolean to operate two bodies.
If the first feature of a body is a negative fature (pocket etc), it will add material.
pockets are a negative body in catia. so that when you use the bolean operation & assemble the part body with negative body(pocket) then it will remove that volume of pocket fom part body.
