2nd tutorial on how to model a wide-chord fan for a turbofan engine in CATIA
Small
**** Steps 16 thru 35. *****
    16. Make 2 more intersection points.
    17. Create the shape shown, following similar procedure as the one before.
    18. Make the profile shown on the zx-axis. The left-most point should be coincident with the H-axis. The right-most point should be coincident with the V-axis.
    19. Make the line shown.
  5. Step 5:
    20. Make a Revolution Surface with both the profile and line you made earlier. The command for it is underneath the Extrude command.
  6. Step 6:
    21. Create a multisection surface. Make sure the closing points are correct.
  7. Step 7:
    22. Create another circle on the yz-plane.
  8. Step 8:
    23. Extrude the circle.
  9. Step 9:
    24. Split the fan blade and extruded circle. Click Other Side if the wrong part is cut out.
  10. Step 10:
    25. Fill in the tip of the blade.
  11. Step 11:
    26. Make the following spiral on the yz-plane.
  12. Step 12:
    27. Enter sketcher on the yz-plane and project the spiral, then offset it and close the ends.
  13. Step 13:
    28. Project the spiral sketch onto the spinner cone.
  14. Step 14:
    29. Extrude the projection.
  15. Step 15:
    30. Split the extrusion and spinner.
  16. Step 16:
    31. Fill in the empty space using the spinner as the Support.
  17. Step 17:
    32. Join the fan blade and its filled-in tip.
  18. Step 18:
    33. Create the rest of the blades by using Circular Pattern.
  19. Step 19:
    34. You are done! Go ahead and render it and admire your work.
    35. If you have any questions, feel free to ask either on here or as a private message.
Please log in to add comments
