Can I performe a swept cut with solid bodies in SW?
Small
tutorial
    First you create a part and sketch a path on it (shown in the picture)
    Than you create a plane where you will create a solid body that will be used as a swept cut tool.
    You must be careful when creating a solid body because the solid body must be placed partly inside the other body. Also, in order to make things work the swept cut tool can only be created as a revoled boss part. If you try to use any other method of creating the swept cut body the swept cut feature will fail. Also, when you revolve a profile of the swept cut body you must uncheck the” merge result”.
    Activate the swept cut tool and select “solid sweep”
  5. Step 5:
    The feature manager is asking you to select the tool body and a path
  6. Step 6:
  7. Step 7:
    After clicking ok you have your swept cut performed and SolidWorks removes the tool body.
Please log in to add comments
