Can I performe a swept cut with solid bodies in SW?
Small
Here is the tutorial.
    Start SolidWorks.
    Select Top Plane and Sketch.
    Make a Rectangle.
    Extrude it.
  5. Step 5:
    Click OK.
  6. Step 6:
    Select Top face of the box and then Sketch.
  7. Step 7:
    Choose Normal to.
  8. Step 8:
    Draw a spline.
  9. Step 9:
    Exit the sketch.
  10. Step 10:
    Select the right face and then sketch.
  11. Step 11:
    Normal to.
  12. Step 12:
    Draw a circle.
  13. Step 13:
    Isometric view and some zoom to the circle. (Don't exit sketch)
  14. Step 14:
    Choose the center point of the circle and the spline. Then choose pierce under property.
  15. Step 15:
    The circle will move to the end point of the spline.
  16. Step 16:
    Exit the sketch and choose swept cut option in Feature tab.
  17. Step 17:
    Choose profile.
  18. Step 18:
    Select the circle as the profile.
  19. Step 19:
    Choose spline as the path and click ok.
  20. Step 20:
    You are most probably done.
Please log in to add comments
