Catia Part Design
Tutorial by G15
Small
this will help...
    first modell the shaft (1)
    first modell the shaft (2)
    first modell the shaft (3)
    you need some point with the specified diameter (1)
  5. Step 5:
    you need some point with the specified diameter (2)
  6. Step 6:
    use variable fillet
  7. Step 7:
    edit the radius an d select the curve
  8. Step 8:
    use the constructed points
  9. Step 9:
    edit the radius to the right measure
  10. Step 10:
    the preview shows some problems...
  11. Step 11:
    select the edges to keep
  12. Step 12:
    selected edges
  13. Step 13:
    the result :-)
Please log in to add comments
