CATIA V5 - how to Push and Pull 3D meshes
These tools are not very known by CATIA V5 users, therefore I decided to make a series about Shape Sculptor.
Step 1: Push / pull curves and vertices
For the case study I made use of the Stanford Dragon, the 3D mesh can be downloaded at https://graphics.stanford.edu/data/3Dscanrep/
Click the Push/Pull icon.
The Push Pull dialog box is displayed.
Define the profile of the sculpted area:
- Smooth
- Sharp
- Circular
- The sculpted area can be defined by: a point
Select a point on the mesh.
Define the influence area around the point:
- Check the Radius button to define a constant influence area (that is the circle around the center point) and display the magenta arrow in the geometry.
- Use the spinners to define the push/pull magnitude.
- Use the arrow to define the push/pull direction.
Click Apply to preview the push/pull.
The Radius button is grayed out.
- One or more curves forming a closed loop
- One or more curves and a part of the mesh boundary
- The mesh boundary
- Make sure the Radius button is unchecked.
