Create a movie in AutoDesk Inventor
Small
I hope this helps you AJA
if you need to know anything else
just let me know and if I know I
sure will help you....
    Click on new top right hand corner.
    Scroll down until you see IPN file type, click.
    It will open in a screen like this.
    Click on the little folder with the eye glass, right hand side of pop up box.
  5. Step 5:
    Will open your folder were all your IPT's and IAM's are.
  6. Step 6:
    Click on the IAM that you want, then click on ok @ bottom right hand corner.
  7. Step 7:
    Will open a screen like this up, click OK.
  8. Step 8:
    Will open your screen like this - with your IAM that you want.
  9. Step 9:
    On the ribbon 2 Icon in click on (( TWEAK COMPONENTS ))
    a little box will pop up.
  10. Step 10:
    Click on - Components and then click on the IPT that you want to move
    Click on - Direction there is 2 ways to move the IPT you can simply drag it or put a value in on the right hand side of pop up box and always make sure you use the USC for the right direction.
  11. Step 11:
    You can also right click on the IAM and select Auto Explode and put the value in that you want.
  12. Step 12:
    After you have finished moving all the IPT's
    Click on the Animate button on the Ribbon top left Icon
    there you can play fast forward and do a few other little things.
  13. Step 13:
    Click save and put the IPN file were you want it....
    Then it is just a case of clicking on the IPN file and watching your little short animation.....
    You can also animate with Inventor Studio :)
Please log in to add comments
