Design of Piston Head in Unigraphics
Hello everyone,
In this video, we are going to design a Radial engine's Piston Head using Unigraphics.
The piston head is the top surface (closest to the cylinder head) of the piston which is subjected to tremendous forces and heat during normal engine operation. A piston pin bore is a through-hole in the side of the piston perpendicular to piston travel that receives the piston pin.
