Doing a cut on 2 faces at different angles in solidworks?
Small
This should do what you are looking for.
    Create a sketch of the shape you want to cut. I sketched one profile, and used offset to create the second.
    Use the Curve - Split command to split the model faces into different faces.
    Select the new faces and use the Surface - Knit command to "stitch" them together into a single surface.
    Insert - Boss - Thicken. This will add thickness to the surface body. I like to use the "both directions" option since it prevents errors related to zero thickness geometry. The thickness of this command will be the depth of the cut.
  5. Step 5:
    Insert - Feature - Combine - Subtract
    Now subtract one body from the other.
Please log in to add comments
