Extrude Boss and Extrude Cut
Learning Outcomes:
1. Geometry creating in Sketch Module
2. Extrude Boss and Cut feature
Step 1: Creating Sketch 1
- Start SolidWorks
- Create New Part
- Select appropriate unit from the lower right side
- Save the part by:
File ==> Save As
- Select Sketch Tab and click Sketch
- Select Top Plane and Select Circle Option from the defined geometry box on the top and taking origin as center draw a circle
- Select Smart Dimension and give dimension of diameter as 200 mm
- Exit the Sketch
Step 2: Extrude Boss
- Open Feature tab and Click Extrude Boss/Base
- Select Blind and Give Extrude dimension as 50 mm.
- Finish the Boss-Extrude by clicking green tick
Step 3: Creating Sketch 2 and Extrude Cut
- This Sketch will be used to cut the previous made extruded circle
- Again, open sketch tab, select the top face of the cylinder and construct a circle at the origin and select smart dimension and give dimension of 180 mm
- Go to Feature tab and select Extrude Cut and give Value of 40 mm
- Finish the Cut-Extrude by clicking the green tick
