How can I merge two or more surfaces together to have one surface?
Maybe this solution is too easy, but you only need the JOIN command
more than 40 surfaces
pick the JOIN command
select all surfaces
result: JOIN (one surface"
or if you need a "dumb" surface
create datum mode
again the JOIN command
one "dumb" surface
