How do i add thickness to a polyline in Rhinoceros 3D
Small
hi Mark Goody,
following picture can guide you to add thickness to any curves
by adding few simple steps while modelling.
    Draw curves and type ( in command Bar ) or click on "options" icon
    In rhino options click " Appearance "
    As soon as you click " Appearance " a drop down pop up will open
    as " Advance setting "
    Click in the " Advance setting " button , you will see " Advance Display setting "and then click on any viewport names ,
    in this tutorial I have used wireframe .
  5. Step 5:
    At the bottom of the pop out menu ( Rhino options ) you will find a copy button,
    this button will make a duplicate copy of the selected viewport. Thus as soon as you hit the button ..
  6. Step 6:
    immediately a " Display mode options " window will open, that says " copy of wireframe"
  7. Step 7:
    Now under " copy of wireframe" we can see " -objects " which is further
    having settings for various objects namely ; points, curves, surfaces and meshes . As we need to add width thickness on the curves ( polylines, ect)
    click on curves button/ tab , upon that you will see " Curve width pixels "
  8. Step 8:
    edit that column as per your requirement ( I have edited it to 5 pixels ).
    than press/ click " ok "
    ( the settings gets saved)
  9. Step 9:
    Now select the curve you want to add thickness to ( I have selected a circle )
  10. Step 10:
    now in command bar type ( keep curve selected )
    " setobjectdisplaymode "
    and press enter key
  11. Step 11:
    Choose attribute for selected object
    ( the selected curves will show the changes only in the active view , i.e in the view in which it is displayed )
    click on " mode "
    or type " M " in key board and press the space key
  12. Step 12:
    ON clicking that you will see all the viewports including " copy of wireframe " ( which we recently created. Choose " copy of wireframe "
  13. Step 13:
    As soon as you click on the " copy of wireframe "
    the command gets over and you find that the curve which is selected have a
    different width thickness than other curves. This change in display can be
    reversed by same method
    ( just click on " user view " in choosing attributes )
  14. Step 14:
    Enlarge the veiwport and inspect, this will not change its apperence in other viewports , you will have repeat same steps in different veiwports in order to see the effect
  15. Step 15:
    Now if you want to see the similar kind of effect in you prints also than he
    under object properties
  16. Step 16:
    There is print width option in the bottom of the op out menu.
    by default its layers , so click on that and..
  17. Step 17:
    edit the value
  18. Step 18:
    Than go to print command
  19. Step 19:
    As soon as you execute the command you can see the
    curve in different width in the print preview.
  20. Step 20:
    I hope this is helpful :)
  21. Step 21:
