how offset emboss works in nx 7.5
Small
Here's a short tutorial made with the Curve option.
    Draw a curve on a surface or either project a curve to the surface.
    Select Offset Emboss. Center Type = Curve. Body to Offset = select the surface. Path to Follow = select the curve on the surface. Set settings as you like.
    Have a surface with offset emboss.
Please log in to add comments
