How to Apply Vivid Materials onto an Assembly in GrabCAD Print
See how easy it is to apply Vivid Materials onto an assembly in GrabCAD Print. This example features a brake light so you can see how the transparency works as well!
  1. Step 1: The Process
    1) Orient your part correctly
    2) Check your loaded Materials to make sure you have the materials you need to make your material assignments
    3) Start assigning your Digital Materials to your assembly parts
  2. Step 2: Related Tutorials
    This tutorial was a fun use-case on how easy it is to apply vivid materials to an assembly. You might also be interested in these tutorials where we break these features down:
