How to convert a .step file into a solid object in autocad
Small
Step to Solid object using Autocad
    First open Autocad and ensure that you are in 3D Modeling Mode..
    Now under Insert selct Import option
    Select your Step file and press Open
    Autocad will take some time to Import the file and once it as finished importing click on the path of
    impoted file which is underlined
    Now you have converted the Step file into solid body in Autocad
    Later you can save the file if you want....
Please log in to add comments
