how to correct dimensions?
To make it easier to explain, I will create a hollow cylinder with an internal diameter of 50mm, After awhile i want to make the internal diameter bigger let's say 70mm.
Below is a tutorial of how to do this ;)
    The hollow cylinder before correcting dimensions
    Right click on the fonction that you did use to make the part, in my case extrude fonction ( as you see it's located on the Left panel)
    Left click on "Edit sketch "
    Double click the left mouse button on the dimension that you need to change
  5. Step 5:
    change the value
  6. Step 6:
    Quit the sketch
  7. Step 7:
    Congratulations you're done,.. final result :)
Please log in to add comments
