How to create a car surfaces based on BMW X6?
Small
you will see some of the advanced method for creating surfaces of a car BMW X6
    1 - open a new file and choose the right plan and click on sketch image
    2 - but we must prepare images before, we choose the image
    3 - we put on the transparent image by clicking on the color of the image bleached by the pipette is left to bottom
    4 - and we do the same steps for other pictures
  5. Step 5:
    5 - .
  6. Step 6:
    6 - and to plan the back by creating a parallel range plan to plan ahead
  7. Step 7:
    7 - After I draw a spline on the image to the right plan
  8. Step 8:
    8 - and extruding the spline
  9. Step 9:
    9 - drawing a sketch on the plane below and we put two lines of construction until the mid plane
  10. Step 10:
    10 - and the same operation on the right plan
  11. Step 11:
    11 - after we make a projection for the two curves
  12. Step 12:
    12 - After you connect the surface created with the projected line
  13. Step 13:
    13 - we create another line near the first projection
  14. Step 14:
    14 - Another projection curve
  15. Step 15:
    15 - After you connect the two spline curve by a closed 3D sketch
  16. Step 16:
    16 - and we perform the sketch
  17. Step 17:
    17 - After we create a sketch on the plane as in the picture below
  18. Step 18:
    18 - and we restrict the part we do not need
  19. Step 19:
    19 - the same goes for the rear side of
  20. Step 20:
    20 - We connect the two surfaces with a 3D spline
  21. Step 21:
    21 - we create a boundary surface as in the picture
  22. Step 22:
    22 - we hide the first area created
  23. Step 23:
    23 - we can create the symmetry
  24. Step 24:
    24 - and we note that the surfaces created are well established in terms
  25. Step 25:
    25
  26. Step 26:
    26
  27. Step 27:
    27
  28. Step 28:
    28
  29. Step 29:
    29 -
  30. Step 30:
    30 -
  31. Step 31:
    31 - We connect the surface created with the projected curve
  32. Step 32:
    32 -
  33. Step 33:
    33 - you will find the model with other steps in http://grabcad.com/library/how-to-create-some-surfaces-of-a-car-bmw-x6
Please log in to add comments
