How to create a mechanism with more than two gears in CATIA
Small
Thanks for the reply. Will this solution work also for stationary rotating gears though? In the end I found a way of doing it that seems to work ok.
I didn't use the gear connection funtion between the gears but instead left the axial rotation of all the connected gears as independant variables. These can then be related to one another at the end by creating a relationship of the commanding variables. I'm using Catia in German so I don't know exactly how the commands are called in the English version but in the mechanism under Befehle (so "commands" I guess) double click to view the properties and then use Verknüpfungen (Relationships would be the English translation I guess). This requires a sketch of a line that is in the same plane as the face of the gears and causes all gears to rotate with the same angular velocity. You can edit the velocity for each individual gear however by editing the function (the fx button) in the window as you create the Verknupfung. Hopefully this is clearer in the little tutorial I've put below
    Creating a Verknüpfung
    Use a line as the common "Verknüpfung"
    Edit the formula to create the correct gear speed for each gear
    Edit the rotational speed for each gear using the factor at the end of each formula
Please log in to add comments
