How to create a Visualize Scene Options (Lists) for Scene States in SimLab Composer?
Small
Visualize scene options for Scene State and Animation Sequences allow users to displaying them as entities in VR Viewer, press "Alt" on your keyboard to show Pins and click "LBUTTON" to select Scene States which appear as entities from the Pins. In this tutorial, we will show you How to create a Visualize Scene Options (Lists) for Scene States in SimLab Composer.
  1. Step 1: Open the SimLab Composer.
    Open the Simlab Composer, you can start the program by double-clicking its desktop shortcut or from the start menu.
  2. Step 2: Create multi Scene States First.
    Before create a Lists, you must create multi Scene States (Create at least two), to create Scene States check this tutorial:
    https://grabcad.com/tutorials/how-to-create-scene-state-for-vr-viewer-lists-in-simlab-composer
  3. Step 3: Create Visualize Scene Options.
    When you finish the previous step, click Actions → Visualize Scene Options, the Visualize Scene Options dialog will appear.
    Select the object which you want to make list for it Ex: Bedside Table, select the table model then click Add Triggers, The object name (Bedside Table) appeared in the Pin and Scene Options side as shown in image below.
    Now drag-and-drop Scene States (which created) from Scene States Library into the VR List1 icon one by one.
    The Scene States will appear under the VR List1 icon as shown in image below.
    You can change the name of list and choose the shapes to display Scene States in VR Viewer from List Properties when click VR List1 icon.
    When you finish, click Apply to save changes.
  4. Step 4: Tutorial Result
    Now, click Start Position and select where you want to snap to.
    Click Launch Viewer → Desktop Mode to start VR.
Please log in to add comments
