how to draw on a curved surface on catia
Small
Another way is to place points on the surface you want to make a curve on and then using the spline command to make a curve and using the surface as support.
    Place points on surface.
    Use Spline command to make a curve between the points and make sure the Geometry on support box is checked and the surface selected.
Please log in to add comments
