How to free mates to allow movement in assembly?
Small
Here is the full solution. When i looked at the assembly i found that the limit angle mate is creating problem. You have mated it in the hinge rather than Header. Maybe this will help.
    Select the Hinge assembly and then component properties.
    Change solve as to flexible.
    Now the first hinge is working.
    Component properties of second hinge assembly.
  5. Step 5:
    Change solve as here to flexible also.
  6. Step 6:
    Mate.
  7. Step 7:
    Select the hinge face.
  8. Step 8:
    Mate it to the face of other hinge.
  9. Step 9:
    Choose Parallel. A error will pop up. We will solve it later. Click OK.
  10. Step 10:
    Now under the mates of second hinge select limit angle3.
  11. Step 11:
    Press Delete. Click Yes.
  12. Step 12:
    Now the assembly is working fine.
Please log in to add comments
