How to make thermal analysis in solidworks 2012?
Here is the Tutorial on basic thermal analysis of rod.
Start SolidWorks in part mode.
Tools>>Addins.
Enable SolidWorks simulation & click OK.
Now under features tab choose Extruded Boss/base.
Select Front plane and draw a circle of 20mm diameter.
Extrude it by 100mm in mid-plane.
Under Simulation tab click Study Advisor arrow and then New study.
Enter name "Thermal Study" and select type Thermal & click OK.
Click apply material in simulation tab.
Select ductile iron and click apply and then close.
Step 11:
Under thermal loads choose temperature.
Step 12:
Select the front face and enter a value of 273.15K which means 0ºC.
Step 13:
Again Thermal loads choose temperature again.
Step 14:
Select the back face and enter 800K value in temperature & Click OK.
Step 15:
Now our model is prepared for the analysis.
Step 16:
Click Run.
Step 17:
Now we can have obtained the temperature distribution. The value of 8.000e+002 means 800K. For an assembly or multipart body analysis having multiple parts we need to add contact.
