How to measure in Rhino?
hi, shawn norbert
Once the dimensions are created , if you want to edit the dimesion just double click ( Left mouse button) and write/ label the desired text.
There is another way for editing dimensions,
use command # object properties
    Select text-Dimension and go to object properties,
    there will be pop up dialogue box of object properties
    !. top most ,click on object , there will be drop down saying "object" -
    click on it you will
    click on it you will get drop down saying Dimensions
    now edit at the value bracket " <> "
    type desired text , like the example in picture
    if you want the dimesion to be edited automatically, then select both object and
    dimension together
  5. Step 5:
    now for example , as I have used scale 1D command,
    and type 6/4.16 , ( always type the desired value first )
  6. Step 6:
    repeat the steps with 2D and 3D scaling as requied
Please log in to add comments
