How to measure my part which is in stl file format?
Small
Hi,
You can measure in Meshlab! There is a tool in the quick acces toolbar.
See below, please excuse my english and my french image !! :)
    Measure in meshlab...
    You can also reduce the number of element of your stl to import it in SW
    Go to filters, Quadric Edge collapse decimation
    SW can handle a maximum of 100 000 triangles for a surface importation and a maximum of 20 000 for a volume importation (you'll understand next)
    Enter the number of triangles. 100 000 is for the best quality, like I said, if you want to open it in SW, but it's really long to open... . Anyway!
    I usually lower the number by 5 to be sure I won't have one extra triangle.
  5. Step 5:
    As you can see, you are not exact (really close)!
  6. Step 6:
    Now you got to export your mesh
  7. Step 7:
    Choose STL
  8. Step 8:
    Open your Solidworks, select STL format and clic OPTION
  9. Step 9:
    Choose the lowest case for surface importation (that's what I talked about in step 3)
  10. Step 10:
    Now wait until your model is created...For the exemple I dropes triangles to 20 000.. That's too long for me with 100 000..
  11. Step 11:
    And you can now measure with measuring tool
  12. Step 12:
    There is an other way to deal with stl in SW, but I don't know everyone have the extension in SW..
    You cannot measure quickly in this method, but you'll able to redraw a stl..
    Export your mesh as .PLY file (.OBJ works fine too). No need to decrease the number of triangle.
  13. Step 13:
    Go to SW, open a new file and activate SCAN TO 3D extension
  14. Step 14:
    Right click on the toolbar and select Scan to 3D
  15. Step 15:
    Now open your file .PLY or .OBJ
    (Sincerely, I don't know why solidworks isn't able to open STL file as a mesh file... You really need to change the format to tell him : ah Ok it's mesh and not a graphic image)
    Now you see your mesh
Please log in to add comments
