How to modify my parametric gear
Small
In this tutorial i'll show how to modify my parametric gear
( Parametric gear )
    Open "Engrenage denture droite" files
    When the .ipt file opens a window appears, In this window you can enter the desired characteristic (Number of teeth...)
    In the 1st tab, You can edit :
    - Module
    - Number of theeth
    - Thickness
    - Pressure angle
    In the second tab, You can edit :
    - If you want a central hole
    - If so, its diameter
    - If you want a key
    - If so, its dimension
    - If you want a Primitive diameter (Circular plane)
  5. Step 5:
    The third tab allows to modify property of the document
  6. Step 6:
    When you validate a new files is generated :
    It's the same file, except that, in is files name, the number of teeth, the module and the thickness is added
  7. Step 7:
    If you want to display the form, You need to activate ilogic browser
Please log in to add comments
