How to move gear horizontally in the shaft and then rotate the gear by rotating the shaft in solidworks13?
Small
I can show you example, but you must read HELP before asking so simple questions!
BTW, I work in SW2015, so the following images will help you.
This video show you what we'll have https://youtu.be/kEXS4TJeSi8
    What we have?
    1) GEAR
    2) SHAFT
    1st mates:
    Inner cylindrical face of the gear
    Outer cylindrical face of the shaft
    2nd mates:
    Two similar planes, e.g. RIGHT plane of GEAR & RIGHT plane of SHAFT
    3rd mates:
    The distance between the 2 faces
    Now you can move gear horizontally in the shaft (changing the distance) and then rotate the gear by rotating the shaft
  5. Step 5:
    4th mates:
    Gear mates make yourself.
Please log in to add comments
