Isentropic flow in a converging diverging nozzle
Missing small
compressible flow is an aspect of fluid mechanics that governs the flow in which the velocity of the flow varies significantly inside the flow channel .the most common example is the isentropic flow which happen inside a converging diverging nozzle with no heat transfer and entropy generation(reversible adiabatic) The use of solidwork flow simulation to design ,simulate and interpret such flow is what this tutorial is all about
  1. Step 1: designing De laval nozzle on solidwork
  2. Step 2: setting up of flow simulation on solidwork
  3. Step 3: interpreting the result of flow simulation and elementry parametric study
Please log in to add comments
