Make a grid in CATIA Sheet Metal using Louver feature
Small
Here is a demonstration showing you the design of a simple grid in CATIA 3DExperience.
The Sheet Metal Design application, based on industry process features, allows you to create quickly a plate that you can bend and add stamps, dowels, bridges, etc.
In this video you will see how to use the Louver feature that allows you to design a grid in only 5 min!
  1. Step 1: Video
  2. Step 2: Create a plate
    Open the Sheet Metal Design application
    * the 3Dpart panel appears *
    Create a 3Dpart called "Grid"
    click on the global parameters
    set the thickness to 0,3mm
    set the radius to 1mm
    * this will apply for all the features of your design *
    Draw a centered rectangle 400*250mm
    Exit the sketch
    Create a wall with the profile
    * the thickness is automatically set up to 0,3mm *
  3. Step 3: Add holes to corners
    Edit the sketch
    Add R20mm fillets on the for corner
    Select the centers of the fillets
    Click on output feature
    * in that way, the points will be shown when you exit the sketch *
    * The points should be visible *
    Create a hole Ø15mm using the point
    * if the hole is not centered with the point, edit the sketch and add a coincidence between the 2 points *
    Do the same with the 3 other holes
    * tips: select the point first, then the plane or surface *
    * The result should be this one *
  4. Step 4: Create the Louver
    Create a sketch on the plate's surface
    Draw a centered rectangle 325x15mm and 110mm from center of the sketch
    * like this *
    Use the louver with the rectangle profile
    Select the opening edge (bottom line)
    Set 5mm in height
    Angle a1 45deg
    Angle a2 80deg
    Click on OK
  5. Step 5: Pattern the Louver
    Go transform tab on the action bar
    click on rectangular pattern
    * select instances and length type *
    Instances 10
    length 220mm
    * be sure that the direction is vertical *
    * here is the result you should obtain *
  6. Step 6: Refine the louver
    Edit the sketch of the louver feature
    Add fillets R7,5mm on the top corners
    Exit the sketch
    * the part will be automatically updated *
    • end of tutorial
Please log in to add comments
