Noob question: How to model a jagged cone
new tutorial.
1.create the cone
2.stop by turning the 2 degrees..middle point,Your cone, will now have a thin slit in it
3. convert the sheet metal , and now we can use Solidworks to convert the tube into sheet metal. Go to Insert -> Sheet Metal -> Bends and change the radius to the radius of the tube, and K-factor to 1.
4.
5.The last thing you need to do is right click on the tube and click Flatten. Your tube should now be flat.
6.sketch
7.extrude cut
8.parts ready
