Tutorial 74: Modeling Lug in ACP (complex geometry):
Small
Solid model settings control how the solid model is divided into elements in the thickness direction and how drop- and cut-off elements are handled. The level of detail required in the solid model depends on how accurate certain features are to be modeled. This depends on the judgment of the designer. Extrusion guides add more complex possibilities in shaping the model. The cut-off operation is analogous to machining a composite part after curing. In this tutorial we are going to use extrusion guide, cut off element and snap to geometry to create complex geometry.
Agenda:
 Create complex composite model
 Import geometry for cut-off rule
 Creating Virtual Geometries
 Import geometry for Extrusion-guides feature
 Extrude solid composite using Extrusion- guides feature
    Please check my website for a tutorial:
    https://www.udemy.com/ansys-tutorial/?couponCode=GRABCADVIEWER
    Modeling composite part in ACP ANSYS
    Modeling metal part in mechanical model
    modeling screws in mechanical model
  5. Step 5:
    Assemble version
  6. Step 6:
    mesh
  7. Step 7:
    analysis
Please log in to add comments
