Tutorial - Analyzing the rod for von-mises stress using Mechanica in Creo Elements/Pro?
Small
Here is the tutorial.
    Start Creo Elements/Pro in Part mode.
    Sketch>>Top Plane and draw a circle of 20mm diameter.
    Extrude it by 200mm.
    Applications>>Mechanica.
  5. Step 5:
    Click OK with default settings.
  6. Step 6:
    Insert>>Displacement Constraints.
  7. Step 7:
    Select front face and click OK. This will fix all the DOFs of the front face.
  8. Step 8:
    Insert>>Force/Moment Load.
  9. Step 9:
    Select the other face of the rod. And Enter an value of 10000 in X at Force and click OK.
  10. Step 10:
    Properties>>material.
  11. Step 11:
    Select Steel and Click >>> button.
  12. Step 12:
    Properties>>material assignment.
  13. Step 13:
    Keep default settings and click OK.
  14. Step 14:
    Analysis>>Mechanica Analysis/Studies.
  15. Step 15:
    Click File Menu and then New Static.
  16. Step 16:
    Keep the default setting for now and click OK.
  17. Step 17:
    Click the green flag to run the analysis. OK.
  18. Step 18:
    Click Analysis menu and then Results.
  19. Step 19:
    Click this icon.
  20. Step 20:
    Select the analysis1 file just created and Click Open. A dialogue window will appear click OK and Show.
  21. Step 21:
    The von-mises stress distribution is shown.
  22. Step 22:
    Click that icon again and under display options check deformed and click OK and Show.
  23. Step 23:
    Now we can see the deformed and undeformed state of the rod under load.
Please log in to add comments
