Tutorial: How to model a fan blade in Catia V5?
Small
Tutorial to model a fan blade in Catia V5
    Create the base on which the blades will be made.Create a point on the lower edge.
    Similarly create a point on the upper edge at a certain lateral distance from the first point.
    Create a 3d line between the points and choose support as the lateral face of the padded object.
    Switch to GSD Workbench
  5. Step 5:
    Extrude the line along zx plane
  6. Step 6:
    Invoke a sketch on xy plane
  7. Step 7:
    Sketch the shape of the blade and make the end coincident with the edge of the padded object.
  8. Step 8:
    Exit the sketch
  9. Step 9:
    Extrude the sketch with reference as the xy plane
  10. Step 10:
    Split out the unnecessary parts by using "split" command
  11. Step 11:
    Hide the extruded part which is not necessary
  12. Step 12:
    Switch to mechanical part design workbench
  13. Step 13:
    Insert->surface based features->thick surface
  14. Step 14:
    Provide some thickness. Click OK
  15. Step 15:
    Tools->hide->all surfaces
  16. Step 16:
    Click on circular pattern
  17. Step 17:
    Fill with appropriate parameters
  18. Step 18:
    After the pattern you will get the required object.
Please log in to add comments
  • Feed
    SHIVAM KESHARWANI
    awesome. I got what i wanted. Thanks buddy :-)
    October 31st, 2016 05:04
