Tutorial - Making text emboss on the curved surface in Creo Elements/Pro aka Pro Engineer Wildfire?
Here is the tutorial.
Start Creo element/pro or pro engineer wildfire in part mode.
Top plane>>sketch and draw a semi circle.
Extrude it as a surface.
Select point tool.
Select the corner of the surface and click OK.
Insert>>Advanced>>flatten quilt.
Select the surface as the quilt and datum point as origin point. Click OK.
Now select the flatten surface and sketch.
Write the text using text tool and exit the sketch.
Extrude this sketch.
Step 11:
Now go to insert>>advanced>>bend solid.
Step 12:
Select bend solid and then flatten quilt from the tree view. Click OK.
Step 13:
Now we have the text on the curved surface.
Step 14:
Right click the flatten surface and then click Hide.
Step 15:
Now we have what we wanted.
