Tutorial: Unigraphics NX mold design : Section 6.1 Mold Parting Tools Region Analysis
Small
Region Analysis Will Bring Up MPV Initialization
    MPV Initialization
    Select The Draw Direction , In My Case i can Select Z direction
    Or the Pull Down Menu Will Provide a lot of Vector Options
    Next Step Will Be Mold Part Validation
  5. Step 5:
    If Plastic Part is Positioned Correctly Provided all Good Draft Angles The Regions Will Be Defined Easily
  6. Step 6:
    In case of Any Undefined Surface , You Can Define it to respective Regions
  7. Step 7:
    Observation : In This Case Due to Positive Draft the Hole is taken in Cavity Side
  8. Step 8:
    if The Region is defined properly , The Parting Line Will Be Visible
Please log in to add comments
