what makes soft blend unique from other blend options
Just adding a tutorial How to Use soft blend, it gives a Clear Idea
    Most Commonly we come across inAccurate Geometry or dead sharp corner Created even after using Edge Blend , this is just One scenario There are Many Other Area we can Explore The Option
    Even if try to Add one more Blend Over it Never Gives an Accurate Result
    and Looks Ugly and Difficult for Cutter to Run While Programing , it could Have Been better if the Fillet Rolled over the Edge
    Here i defines Few lines, and I am Forcing My Blend to Follow the Path Which I want it to Follow, Usually in Edge Blend i will not Have any control over the Edge of the Blend
  5. Step 5:
    Starts With selecting First set (First Face)
  6. Step 6:
    As usual like Face Blend select second Set (Second Face)
  7. Step 7:
    And Defines First Tang ency Curve ( Same side of First Set Face)
  8. Step 8:
    And Defines second Tang ency Curve ( Same side of second Set Face)
  9. Step 9:
    and Defines Center Spline Curve
  10. Step 10:
    The Result Can Be Obtained as , the Blend flows following the Defined Tang ency Curves
  11. Step 11:
    Comparison with " Edge Blend " and " Face Blend "
    Conclusion: just like as we can Define the Edge of a surface in Through curve Mesh, we can define the Edge of Blend or in simple words we can Force Blend to Follow the Path we like
Please log in to add comments
