Analysis error after STL to CATPart conversion .
I have converted a stl to catpart.
But during analysis in catia I get this error.
"Part body of Part 1 is empty or external view is not defined on studied surface."
How can I resolve this issue?
Accepted answer
I've seen mixed results from Catia importing mesh data, usually the issue lies with the data not being manifold (i.e. 'water-tight') or consisting of issues such as overlaps, intersections and similar. I am not an expert with Catia, so I can't help with that aspect, but I recommend that you take a look at the correctness of the STL file using other applications and make sure that it a closed solid (manifold/watertight) and ideally that you are importing individual parts, one at a time. There are a number of free applications (or with free trial) available on the web that allow you to check the file for issues and if necessary make adjustments.
Please let me know if this is helpful...
0 Other answer
