Best rendering software for beginner?
13 Answer
What CAD program are you using?
Of all the rendering programs I have used (admittedly not many), PhotoView 360 that comes with SolidWorks is by far the easiest. It gives very good results as well
Keyshot is what I use. Since you are using Solidworks, photoview 360 is also very good.
Another alternative is Autodesk Showcase but Keyshot and Photoview will give you all you need.
The first rendering software I used was PhotoView 360, the easiest so far, I learned everything in it in about 15 minutes ... I did my first renders in it and they turned out okay, you can see them on my page here ... though PhotoView 2011 is different ...
I use KeyShot also now, more options, easy to use and really good results ...
Every other software I've seen is far more complicated ...
It has to be Keyshot
I have used a couple now and by far for the little effort and big rewards you get over any other rendering software has to be Keyshot.
