Can anyone help me tO design this Piece in solidworks or mastercam for cnc machining?
Easily done by putting your images into Autocad and tracing them to arrive at the curves and geometry provided that its okay to be within +/- .010" tolerance. The
the only issue is that it would need to photographed right next to a ruler in all your views, then using one of the longest dimensions provided. As it is there is nothing to determine the size other than a best guess. This method works very well, but all of the geometry that does not have a specific dimension provided will be relative to the one that is given. That is why its best to give the longest one you can. In practice I have reverse engineered aerospace parts to within +/- .010" and sometimes this is okay, and sometimes it is not okay and requires multiple iterations to get critical dimensions correct. After this the sketches can be imported into Solidworks or another CAD program to be 3D modeled from that information.
