do we need that many Pulley in a conveyor system?
Why would we need a pulley to adjust the tension of the belt in a conveyor? Can we just measure a fixed length of the belt instead?
Accepted answer
it depends on your requirements
the takeup-pulley and the two bend pulleys are use to tension the belt. Alternatively you can e. g. pull the tail pulley horizontally (the head pulley seems to be the driven one)
the snub pulleys are used to increase the wrap angle between tail resp. head pulley and the belt. This is often used when the belt is driven by friction between pulley and belt to increase the drive force to the belt.
