hello I want to create edge flange in Sheet Metal in solid works with Flange Length/Up to the edge and merge but i do not know how I can do that please give some instructure .thank you
I can not create edge by using edge flange
Hi,
I have attached an image- you need to choose up to the edge and merge as the flange length.You can change where the bend begins using the 'flange position' menu on the left.
I have done this between two individual sheets- what is the scenario you are having problems with?
