hello sir. I need a help from u. I have a copy of drawing in auto cad. i want that drawing in pro e, since i dont know pro e can u pls help me,. i ll be sending u the drawing soon
By manzoor on 15 Jun 14:52 4 answers 467 views 0 comments
  • e19
    e19 11 months ago
    Open a new part file. Activate any sketch feature command you need e.g. extrusion. Go to the sketcher and click on menu bar Sketch->data from file, locate the dwg file of AutoCAD and click ok (don't forget to change the filter to dwg). you will have to tell the position and scale for the sketch and job is done. you can modify the sketch if you want to. The problem in this way is that Pro/E applies the constraints automatically which, most of the times, changes the profile.
    2. Open a new part file. Click on the menu bar insert->shared data->from file, change the filter to dxf and locate the AutoCAD file (make sure that you have saved the file in dxf in AutoCAD), click OK and then you will have to select the coordinate system, you can select the default as well as a new coordinate system. Now any section or any line/curve of the sketch can be used in the new features. Use-edge command will be used in the sketcher mode to select the sections. The problem in that way is that you can not edit the profile once you have imported it in Pro/E. But if your profile is final in AutoCad then this is the best way to work.
  • wg123
    wg123 11 months ago
    start proe: 1)file-->new->name enter--->no choose temptate-->mmns_part_solid-->ok
    2)feature-->creat-->solid-->protrusion-->solid,done-->sketch plane choose
    redo the line and circle like cad.--->then choose direction and height--->choose tick label
  • wg123
    wg123 11 months ago
  • sandesh jog
    sandesh jog 9 months ago
    well wat kind od drawing is it about which part any name of it?
Add your answer to: "hello sir. I need a help from u. I have a copy of drawing in auto cad. i want that drawing in pro e, since i dont know pro e can u pls help me,. i ll be sending u the drawing soon"
