Help me to design a casing for recruiter's challenge.
I have a challenge from recruiter to design a casing for electronic parts like a cellphone and it should be waterproof I have no Idea how to make it waterproof and it should have usb port, sim slot and pin button and also Provision for backlight for company logo don't know where to start and no references.
Do you have Electronics Design already? if not it will be difficult to make a case. You might need the layout of the electronic components/peripherals. If you have no references and if it is a new product, you have great freedom to display your creativity, probably what the recruiter is looking for. Start with a rough case of what you think is optimal for the need and go on building/editing/changing/redesigning from there. I am afraid I cannot help you further with the informaiton you have given.
