how can i assign a pic to a surface in keyshot?
i have designed a LCD and i just want to have a picture on that LCD to show that the LCD is on and is working how can i do that?
12 Answer
You right-click on the surface and click Unlink material at first. Then you double-click on the same surface again and you click on tha label tab next to the texture and properties tab and you add your picture.:)
Hope i helped.
Hey, you can do it with the option "Decals"
You will find more information about that subject on:
http://help.solidworks.com/2011/English/SolidWorks/sldworks/AllContent/SolidWorks/Core/Display/Decals/c_Decals.htm
and:
http://www.5min.com/Video/Solidworks-2010-Tutorial-PhotoWorks-Decal-288604289
There's no problem if you don't unlink material. i thought that it would put he picture into the whole body but if it doesn't, just skip that step.
yeah Alireza... just prepare your picture in photoshop first, then add your model on keyshot kai take the steps i told you above. that should be it.
http://www.keyshot.com/keyshot3/manual/labeling/overview.html
i found this tutorial really useful, if this is what you're after.
also I'd recommend always using .png images with transparency (so no visible border). you can make these in photoshop, and keyshot will import them.
but why i should unlike the part at first. i did one time with unlike and one time without it and nothing changed and same result?
