How can i change the 2D FEA calculation units in autocad mechanical i.e. lbf to N, psi to N/mm^2 ? pushkar narwadiya 26 Nov, 2018 06:44 AM While applying the force in 2D Fea analysis in Autocad Mechanical, i haven't find any way to change the force unit from lbf to N? What will be the process for the same? 1 Answer AnMay Answered on 29 Nov, 2018 01:57 PM The units are taken from the template. So you have to use the command "New" and choose a template with the desired units (e. g. AM_iso.dwt). AFAIK that's the only way (Version 2018)
