How do I fill text in Creo Parametric when projection
Hi, I want to make a projection of a text, but I want that the text appears filled, not the contour.
Yes, that's an option, the problem is when the surface you want to project to is curved.
I've reached to a solution that is hatching the text from the sketch, then you define the hatch lines so close to each other, that the appearance is like if the text was filled. I know that this is not the same, but it's a valid solution for me.
Thanks for your answer
