How to create a mechanism on STEP file with Creo Parametric
When I start the Creo Parametric 2.0 with the step file, I see assembly and all part files on the screen. How can I create a connection between the part files as I desire, because all the plane, point and axis display are missing with this STEP file. Well, I can create the necessary plane, point or axis on part files but if there is a short cut of instead of my solution, could you give me an advice? Thanks.
