How to do a belt wheel in inventor Gayla Napier 20 Nov, 2022 06:51 PM small belt wheel 36 teeth - dimensions given on teeth detail 25 degree angle , 2.50 distance from one edge of tooth to the other with 10degrees given center to center of each tooth Belt Wheel 1 (Small) (2).pdf Accepted answer Carlos J. Veloso Answered on 20 Nov, 2022 11:11 PM Sketch Tooth, Sketch Body, Extrude Body, Extrude Teeth... 36 Tooth Gear .png 36 Tooth Gear Extrude Gear.png 36 Tooth Face Extrude.png 36 Tooth Sketch 3.png 36 Tooth Sketch 2.png 36 tooth Sketch.png 0 Other answers
