how to do dynamic simulation of material removal of work piece by tool bit? nissi paul 21 Mar, 2016 05:43 AM in cnc or lathe machine by giving speed rate constant,feed rate varies and speed rate varying,feed rate constant. 1 Answer Pete Strycharske Answered on 18 Apr, 2016 02:29 AM If you have access to Fusion 360 from Autodesk, you should be able to upload the model and use those CAM tools. The tools show the material being removed when you run the machining simulation. Hope this helps and have a most blessed day! Peace, Pete
